Water Block
Go to solution Solved by Oshino Shinobu,
Well, this is one..
And this is another, but not a stock backplate (looks similar though)
Should be an option under my post to mark it as solved.
I am going for a red and black color scheme is their any back plates you recommend.
 U attactched the picture it dosent show me the option
"In the middle of every difficulty lies opportunity."
- Albert Einstein
https://linustechtips.com/topic/424293-water-block/#findComment-5696188
Ah, it's because it's in off topic.
EDIT: EK has some red backplates if you like them.
EK-FC-R9-290X-Backplate_red_590_card_web
https://linustechtips.com/topic/424293-water-block/#findComment-5696197
 Link please
I don't know what card you have. Only one EK have on their site is for the Titan X https://shop.ekwb.com/ek-fc-titan-x-backplate-red
Though it does fit on quite a few blocks for the 980Ti and M6000 as well http://configurator.ekwb.com/waterblock/3831109830628
https://linustechtips.com/topic/424293-water-block/#findComment-5696256
How did you know did i wanted to get 980ti?
- Albert Einstein
https://linustechtips.com/topic/424293-water-block/#findComment-5696275
Guest
