I just completed my first build and when I go to turn it on it turns on but will show the main BIOS screen for a few seconds then will show me the screen that says,
"Reboot and Select proper boot device
or Insert Boot Media in selected Boot device and press a key_"
Yes, I made sure my HHD and SSD are connected via SATA to the motherboard and the HHD and SSD are connected to the PSU.
https://linustechtips.com/topic/424220-help-with-build-boot/
You have to install an operating system
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/424220-help-with-build-boot/#findComment-5695091
lol /\ this.
make sure you install it to the ssd as well.
And set the boot order correctly
I am not very experienced so how do I install an OS when I see this screen?
Also, how do I chose to make the SSD the C drive where only windows is installed?
And lastly, what does boot order mean?
https://linustechtips.com/topic/424220-help-with-build-boot/#findComment-5695134
There are tons of tutorials on youtube about this stuff.
You have to put a Windows disk in your CD drive or put a windows file on a USB stick. How to do this, can be found on the interwebs.
In the setup, once your windows installation is running, you can choose your drive where you want to install your OS on.
The boot order can be changed in the BIOS, which can be entered pressing delete while you're booting up your PC.
Any questions ,just ask on this forum!
https://linustechtips.com/topic/424220-help-with-build-boot/#findComment-5695173
Plug your SSD into the first possible SATA slot. (SATA 0 most likely)
Go into your BIOS by pressing DEL or F12 while the computer is starting
Look for "Boot order" or "Boot configuration" or something of the like. Set your SSD to 2, your HDD to 3, and whatever you're installing your OS from to first
Use a Windows installation disk, or make a bootable USB drive. Win10 USB Creation tool Windows 8.1 USB Creation tool (you need to buy a product key for Windows if you haven't already)
Your computer should boot to the Windows installer with further instructions. Make sure to install to your SSD! You will be given the option of which drive to install Windows to. After you finish installing Windows, remove your Windows installation media (The disc or USB drive) and your computer should start into Windows
https://linustechtips.com/topic/424220-help-with-build-boot/#findComment-5695184
