I bought this laptop from a friend that said it wouldn't power on and kept restarting at the screen that says the manufacturer's name. I immediately knew it was the hard drive and bought it off of him for cheap. I put a new copy of windows 7 home premium on it and VOILA, a functioning laptop!
See, this is where the problem happens. So I can't tell if caps lock, num lock, or scr lock (I think thats what it is) are on or not. With my other laptop, an symbol of whatever I presses would pop up in the middle of the screen. I am wondering if it is even possible to get that on this laptop or if ill just have to live with it.
https://linustechtips.com/topic/424161-caps-lock-issues/
Look for lights. Otherwise, there must be some software solution out there.
Dunno about Windows, but Gnome has an extension that does just that.
https://linustechtips.com/topic/424161-caps-lock-issues/#findComment-5694510
