I want to add a second 980 Ti to my system (I have an EVGA SC with the reference cooler) and I've been stalking NewEgg's website for weeks now but they have not had any in-stock for awhile. They have cards from other manufacturers (Asus, Zotac, etc.).
Since I want a reference card, does it matter if the manufacturer of both cards in my system are different?
https://linustechtips.com/topic/423607-question-about-reference-980-tis/
the card itself should be the same, if its reference. maybe with slightly different clocks, but that wont matter in sli.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
It's fine, you can add different brand as long as it's 980Ti.
Here: http://www.geforce.com/hardware/technology/sli/faq#c17
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
nope any gtx 980tis will owrk togeather just buy another brand it doesn't mater
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
imo you shouldn't have a reference 980 Ti as it literally throttles itself (it can't handle it) but yes, it will work.
Thank's for the info guys, I will order another brand then.
I'm with you on the throttling but I will be watercooling the card (existing card is already watercooled).
