http://pcpartpicker.com/p/WH8BRB
There is my build but I would like to know if my memory would work with it. The RAM is DDR3 at 1866 but this motherboard doesn't support that so would it work or not?
You should be able to run it just fine. Worst case if you can't get it up to 1866 you should be able to run it at 1600mhz with no problems and no noticeable (if any) performance decrease. However I'd suggest getting an SSD if possible BUT NOT a Kingston V300.
Also please follow your topics by pressing the 'follow this topic' button at the top-right of the page.
Sig under construction.
https://linustechtips.com/topic/422588-need-help/#findComment-5674595
