Ghosting a drive
Solved by MrBucket101,
So I'm going to need to ghost a new laptops hard drive onto a SSD so I can use the SSD instead of the HDD without having to reinstall everything. What programs do you guys recommend for this?
clonezilla
but you'll need to manually shrink the source partition down to size beforehand, as it can't do that. I use gParted to do that
1
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
4
6
play_circle_filled
Latest From ShortCircuit:
