With the extra student loan money this semester, I've decided to ascend.  I have a friend majoring in computer science helping me out, and he recommended posting it here.
Budget: $1000 (including peripherals).
Goals: Longevity, using Adobe Photoshop, gaming every once in a while. These are hobbies, not my career choice.
Planned upgrades: More RAM, and a better GPU. Maybe an HDD.
PCPartPicker list
CPU - i5-4590 3.3GHz
CPU Cooling - Hyper 212 EVO
Motherboard - ASRock H97M PRO4
RAM - 1x8GB DDR3-1600 (Crucial Ballistix Sport)
SSD -  Sandisk 256GB
GPU - MSI Radeon R9 290 4GB
PSU - Thermaltake SMART 750W
_
Monitor - Acer H236HLbid 60Hz 23"
Keyboard - Poseidon Z
Mouse - Razer Abyssus
The reason I haven't included an HDD is because I've lived comfortably off of ChromeOS. I don't need that much space.
What do you guys think?
PCPartPicker List (After Recommendations)
RAM - 2x4GB DDR3-1600 (G.Skill Ripjaws Series)
SSD -  Samsung 850 EVO 250GB
PSU - SeaSonic 620W
_
https://linustechtips.com/topic/422210-first-pc-build-critique/
I would change PSU but other than that it's good
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5669862
If you dont plan on over clocking I think this is a good build @GrahamxReed follow your topics!
[spoiler=Blue^3http://linustechtips.com/main/topic/388528-blue3/ I5 4690k | Asrock Z97 Pro4 mATX | RAM: Corsair Vengeance (2x4GB) Blue Edition and Corsair Vengeance (2x4GB) Black Edition | GPU: XFX DD R9 390x | PSU: Corsair AX760 | SSD: Samsung 840- 120GB | Hard Drives: 2x1TB WD Blue | Watercooling Kit: XSPC Raystorm 240
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5669863
I think photoship can benefit from hyperthreading, for $40 extra, consider this: http://pcpartpicker.com/part/intel-cpu-bx80646e31230v3
You get no integrated GPU, but otherwise it's basically a cheaper i7.
 CPU:  Intel i7-4790K      Cooler:  Noctua NH-D14     GPU: ZOTAC GTX 1070 TI MINI     Motherboard:  ASUS Z97 Gryphon     RAM:  32GB G Skill Trident X
Storage: 2x 512GB Samsung 850 EVO (RAID 0) / 2TB Seagate Barracuda     PSU: 850W EVGA SuperNova G2     Case: Fractal Design Node 804
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5669907
UGH change the PSU
Maybe consider a Xeon
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5669908
That PSU makes me cringe ._.
Use to have a TT Smart SE 630W - started whining, clicking and so on. Changed it.
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5669921
UGH change the PSU
What do you recommend for a PSU? Reddit's /r/pcmasterrace builds has an EVGA 850W.
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5670215
I'd suggest a SeaSonic M12II 620W.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
Modular and great quality.
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5670226
  1. get 2 sticks of ram at 4gb
in terms of the ssd at the 85 dollar price point, i would get an 850 evo from samsung instead
the 290 is fine, but it gets very hot when under load. if you can squeeze a 390 in instead, that would be better as i've heard they have much better cooling
i don't know anything about your psu. i go for evga gs or g2 psu's or seasonic ones
your monitor is a bit cheap for gaming. ideally, you want a 1ms and 144 hertz monitor for playing games. if you can save up more and buy one of these at a later date, i would do that
other than that, the build looks good!
BigDay
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5670371
  1. in terms of the ssd at the 85 dollar price point, i would get an 850 evo from samsung instead
  2. your monitor is a bit cheap for gaming. ideally, you want a 1ms and 144 hertz monitor for playing games. if you can save up more and buy one of these at a later date, i would do that
#1 The ssd is his only drive, there's no reason not to spend the extra 20 bucks and get double the space.
#2, I agree he might want to spend a bit more on it. But 1ms at 144hz makes absolutely no sense for him. He said going to be doing photoshop in addition to gaming, which means a tn panel wouldn't work. and the difference between 1ms and 5ms is completely negligible, that's 4 thousands of one second, and ghosting shouldn't be a problem under 10ms. and a 290 isn't going to be pushing 144hz on any decent quality in most modern games.
EDIT: yes I know the numbers got messed up when I deleted the unnecessary lines.
"LTT's official.."STOP. I promise you aren't LTT's official bagel eater or whatever. Trust me.
https://linustechtips.com/topic/422210-first-pc-build-critique/#findComment-5670538
