need a case
Go to solution Solved by mata-pombos,
yea was thinking about that my selfs i think i gonna get that case
it´s very good, good ventilation, good room for water cooling and it has dvd support...
hi there
i need a case for a upcoming pc build,
first of all i got a budget for around 100 EURO for a case
(i live in belgium, most of the stuff is bought on alternate.be
the case needs to fit the following
a top mounted (preferred) 240mm radiator (h100i gtx)
gtx970
DVD drive
ssd and hdd drives
bonus for something red but otherwise colors don't matter
sincerely
a guy thats needs a case
https://linustechtips.com/topic/422170-need-a-case/
yet to overpriced and not available here
$100 is overpriced for the Enthooo?!?!?!??!?!?!?!?!??!It's like the best bang for buck case out there
The fractal design R5 should be good.
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/422170-need-a-case/#findComment-5669411
has it good airflow ?
r4 has good enough airflow for intel cpu and a 970. also it's very quiet.
https://linustechtips.com/topic/422170-need-a-case/#findComment-5669438
