I had eDrive working when I used Windows 8.1. Since I upgraded to and reinstalled Windows 10 I can't get it working, nor do secure erase. What I have to in order to enable encryption again?
do a clean install of the os
should fix all the problems
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/422045-edrive-wont-work-again/#findComment-5668087
