Hello, I was just posting to confirm that this build will in-fact work, This is my first build and I want to know anything from cheaper parts, to the amount of fans the the fan controller can take, wire length problems, or anything you can see, thanks in advance!
Nicholas,
http://uk.pcpartpicker.com/p/Bfw4TW
https://linustechtips.com/topic/421793-general-help/
what cpu?
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/421793-general-help/#findComment-5664911
thats perfect. I know for a fact that the phantom also has some fan leads pre-installed going to the stock fans that come with the case.
Any idea how I should setup the fans, I was going to put 2 120mm in front 3 120mm in top and 1 140mm in back, then throw the fans that come with it out, any idea how I could keep all?
https://linustechtips.com/topic/421793-general-help/#findComment-5664969
you might want to keep the fans that come with the case, just in case, (no pun intended, jk all puns intended). I would push in from the two in front and the back 140mm, then pull out the top. And if your motherboard has 6 fan headers, I would control them with the motherboard. It depends on your preference. If you want to get really fancy, get the Corsair link commander mini. with it you can control fans, rgb led strips, and monitor temps in your case, all from your OS.
https://linustechtips.com/topic/421793-general-help/#findComment-5665054
I think this will work.
CPU: AMD Ryzen 3700X | Mobo: ASUS Strix X570-I Gaming ITX | GPU: Nvidia GeForce RTX 3060 Ti Founders Edition | RAM: Corsair Vengeance RGB PRO 16GB 3600MHz | Storage: Corsair Force MP600 1TB PCI-e Gen 4 & 2x 2TB Seagate Barracuda | Cooler: Stock Prism | Case: NZXT H210i | PSU: Corsair CS500M
https://linustechtips.com/topic/421793-general-help/#findComment-5665497
