Hey LTT
I'm debating whether to get two intel 535 240GB SSDs or two Samsung 850 EVO 250GB SSDs. They are the same price.
Before you say get the samsung, it's faster, it's better, it's more reliable, 3D NAND etc, the 850 will clash terribly with my all-white build, where as the intel would fit in nicely.
The 840 colour scheme could work out well, but it has had some issues, and, for some reason, it is more expensive. Maybe i could purchase an 840 casing and put an 850 in it?!?
Will there be noticeable performance, reliability and life-span differences between the two?
Also, I've heard that Intel are performance-consistent SSDs, and I will be running them in RAID 0.
If I've said something wrong, please correct me
My Builds:
Peripherals:
Keyboard: Roccat TKL Pro Cherry MX blue, Mouse: Roccat Kone XTD, Headset: Currently apple earbuds, planning to upgrade to hyperx cloud or hyperx cloud 2
Really Old Desktop
 Processor: Intel Core i7 920, Motherboard: Gigabyte GA-FX58-DS4, RAM: 9GB Corsair XM3 (3*3GB in triple channel) 600 or 800mhz, Graphics Card: Asus 8400GS passive, Asus GT630 4GB if i can get it working, Case: Cheapo Throwout case with most of the standoffs missing, HDD: Some old 80GB hard drive, PSU: Thermaltake Toughpower 550w, Monitor: 32" Kogan TV, OS: Fedora 13
 Laptop Which I Use For Everything:
Processor: Intel Core i5 3337U, RAM: 8GB (2*4GB) 1600MHZ, Graphics Card: Nvidia 710m HDD/SSD: WD Black2 Dual Drive, OS: Windows 8.1
 40 GB/s Network Tester
Processor: Some really good Intel Core i3, Motherboard: Gigabyte GA-H67N-USB3-B3, Ram: Corsair Value Select 4GB (2*2GB) 1600MHZ, Graphics Card: Integrated, Case: Some 1U rackmount mini-itx case with no front bays, HDD: Seagate Momentus 5400, 250GB 2.5" 5400RPM, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 40Gb/s QSFP+ PCIe 3.0 8x NIC, Monitor: any ones lying around, or 32" Kogan TV, OS: CentOS 6.2 (I Think)
Planned 100Gb/s Newtork Tester
Processor: Intel Core i7 4790k, Motherboard: Asus Maximus VII Impact, Ram: Kingston or G.Skill 8GB 2400MHZ Low Profile, Graphics Card: Integrated, Case: 1U Rackmount ITX case, HDD: Samsung 850 EVO 120GB, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 100Gb/s PCIe 3.0 16x NIC, Monitor: Any lying around or 32" Kogan TV, OS: Fedora 22 or CentOS
https://linustechtips.com/topic/421399-ssd-help/
If you are worried about colour schemes then I would go with the one that best fits in with it, the Intel.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/421399-ssd-help/#findComment-5660148
Maybe you should pick up a Kingston Hyper X 3K.  It is white, and fast.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/421399-ssd-help/#findComment-5660174
