CPU: Intel Xeon E3-1246 V3 3.5GHz Quad-Core Processor  ($276.99 @ SuperBiiz)
CPU Cooler: Noctua NH-L9i 57.5 CFM CPU Cooler  ($42.88 @ OutletPC)
Motherboard: Asus H97M-PLUS Micro ATX LGA1150 Motherboard  ($99.00 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($102.89 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card  ($350.73 @ B&H)
Case Fan: Cooler Master R4-L2R-20AC-GP 69.0 CFM 120mm  Fan  ($5.99 @ NCIX US)
Case Fan: Corsair Air Series White 2 pack 52.2 CFM 120mm  Fan  ($20.49 @ OutletPC)
Other: Fan Spliters  ($10.00)
Total: $1166.93
Generated by PCPartPicker 2015-08-01 23:19 EDT-0400
I guess i decided on this processor for more uhh . braggin rights ...
I dunno if i could if a liquid cooler as a rear in this case that why i didnt opt for it.
What do you guys think of this?
Do you have and psu and fan recommendations? (trying to be as silent as i can + lighting for showin off)
No i will not consider AMD.
I am planning on a 144hz monitor, but what keyboard should i get? i havea deathadder as a mouse and i am content with it.
I am a ... NVIDIA FANBOY!
https://linustechtips.com/topic/421253-1200-intelnvida-node-build-updated/
@ArataMaou
  1. added an excellent aftermarket cooler in the noctua u12s
  2. added higher frequency ram
  3. added a 390 as it will perform better. around the same price
  4. added a fully modular psu @ 650w
  5. added a noctua nf-s12a pwm fan for case ventilation
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($64.99 @ Mwave)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($46.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Best Buy)
Video Card: Asus Radeon R9 390 8GB Video Card  ($339.99 @ Amazon)
Case: Fractal Design Node 804 MicroATX Mid Tower Case  ($84.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($95.11 @ Mwave)
Case Fan: Noctua NF-S12A PWM 120mm  Fan  ($21.10 @ Amazon)
Total: $1192.04
Generated by PCPartPicker 2015-08-01 23:32 EDT-0400
BigDay
@ArataMaou
Total: $1192.04
my mobo doesnt suppport that ram
that fan looks horrible (aesthetics)
im a new builder when it comes to a smaller case so i went semi modular for saving time and hassle ..
yes it does support it. you just need to see if it works. if it doesn't, you raise the dram voltage. the fan is the best on the market. your last statement made no sense. fully modular is the best for new builders. no bullshit wires.
you're welcome by the way
BigDay
Can i ask .. is 550w enough for the build that i posted?
Fully modular is better for small cases,
Personally get a cheap air cooler, you won't be overclocking on this anyways so a BeQuiet! Pure Rock is an excellent choice.
@BigDay has a good built. Turn the noctua into a pure rock, add some ?BitFenix led fans or BeQuiet fans.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
