*URGENT* compression fitting question
Go to solution Solved by W-L,
That's hardline that needs the collars glue in place with UV glue to hold the fittings in place to seat against the rubber o-ring:
http://www.performance-pcs.com/monsoon-hardline-uv-cure-adhesive-for-acrylic-8ml.html
i have some monsoon compression fittings, and i can pull the tube out relativley easy, is this normal?
Which fittings do you have the hardline or soft tube stuff, you shouldn't be able to pull them out.
and i just realised that those are acrylic fittings, thanks anyways.
