VGA quality depending on device?
Solved by sirtoby,
ok. i bought a dvi-d cable and it works perfectly.
my problem turned into following one:
display one is connected via dvi-d
display two is connected via HDMI and is also recognized by the system (showing up in the menu to change displays and resolution) but it stays black and says "no cable connected".
do you know this problem?
Do you have a way to manually choose the source on your monitor? My screen has sometimes problems detecting hdmi input, so I have to manually set it.
