Windows 10 Sound problem
Go to solution Solved by ShadyHost,
Hi there.
I just recently upgraded my PC to Windows 10 and I now have no sound on my computer. Previously I used to get my sound from my TV via HDMI. I also tried to see if I get sound through earphones and I do.
I trouble shooted to see what problems there was and it says no peripheral or device connected. I have assumed that the problem is that I now need to use speakers to get sound on my PC am I correct in assuming this.
Thanks
Sound over HDMI is handled by your graphics driver. Make sure that is updated to the latest Windows 10 version.
Hi there.
Thanks
https://linustechtips.com/topic/420587-windows-10-sound-problem/
Hi there.
Thanks
https://linustechtips.com/topic/420587-windows-10-sound-problem/#findComment-5650751
