It really just depends on what you prefer. For looks, all in one is far better looking imo. For noise, however, that Phanteks cooler will be much quieter. Expect similar performance.
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/420494-cooler-decision/#findComment-5649757
Probably seidion because the air cooler is so small.
The TC14CS is hardly small. Keep in mind that it uses 140mm fans.
http://www.hardwaresecrets.com/phanteks-ph-tc14cs-cpu-cooler-review/6/
Which performs better will depend on how the case airflow is setup. The Seidon has the advantage of directing heat outside of the case with the mounting location. In an optimal scenario for either, the TC14CS would perform better.
https://linustechtips.com/topic/420494-cooler-decision/#findComment-5654279
