I got my MBP '12 back from the shop today. I had put some old cheap HDD in it with OSX installed so my SSD (MX200 500gb) would not be damaged I assumed the laptop was shut down and went to switch out the drives (No fans or drive spinning and the power light wasn't on) but apparently the laptop had just been set to sleep when I picked it up. Now the it shows the folder with ? on it (OSX BSOD). Did the drive just get corrupted or is it actually broken since it shows up in windows just not formatted for windows and if it is just corrupted is there any way I can recover data, most of it is backed up but not everything.
My Build
 - i5 4670k @ 4.4GHz - MSI z87m Mobo - 16Gb 1866MHz RAM - MSI R9 290 - Samsung 840 EVO 250Gb - 2 x 1Tb WD Blue - CX600m - H55 AIO cooler - Fractal Node 804 - Lg 25um64-s Ultrawide screen monitor -  http://pcpartpicker.com/user/colec18/saved/9FKXsY
https://linustechtips.com/topic/420425-ssd-problems-after-installing-drive/
Why wouldn't you take the battery out when working on a laptop in the first place??
CPU: A10-6800k @ 4.7 Motherboard: Asus A88X-Plus RAM: Kingston HyperX 2 x 4 GB GPU: PNY GTX 660 Case: Corsair 450D Storage: 500 GB Samsung 850 Evo, 120 GB Samsung 840 Evo, 1 TB WD Blue PSU: Corsair HX750i Display(s): Asus VS248H-P Cooling: Noctua NH-D14 Keyboard: Amazon Special Mouse: Corsair Raptor M45 Sound: Amazon Special Operating System: Windows 7 Pro 64-bit
It's a non-removable battery.
My Build
ummm what macbook pro with a removable 2.5in drive doesnt have a removable battery??
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
