When i push the power button (nothing is on the display), my fans turn on all the lights come on, then it shuts down, then it boots. it never did this before, maybe i messed up xD. im running a AMD FX-6100 @ 3.6GHZ on an H80I, A GTX 660 OC, 8GB Kingston Hyper X BLU, I have a Corsair 760I, all on a GIGABYTE UD3, i dont know if the HDD's Matter but i have a 1TB burracuda and a 60GB Kingston SSD for the OS, im running Windows 7 64Bit. Thank you for the help.
Computer Eqiupment:
https://linustechtips.com/topic/41969-start-up-issue-maybe/
Does your mobo have error codes?
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/41969-start-up-issue-maybe/#findComment-545659
 (FANS ARE LOUD)
 The H80I Light hasnt worked for awhile, the H80 works fine all the fans are hooked up to it and run, and the link software picks it up perfectly
Computer Eqiupment:
https://linustechtips.com/topic/41969-start-up-issue-maybe/#findComment-545823
Remount the H80i. The waterblock must not be touching the CPU correctly, causing it to overheat, which causes the motherboard to tell the fans to go full blast. This happened on my old Dell when the system was abnormally unstable, and the PWM fans were on 100%. Turned out the base of the heatsink wasn't making good contact with the IHS, because there were no thermal paste between them. I fixed it by applying new thermal paste, and it is now silent.
https://linustechtips.com/topic/41969-start-up-issue-maybe/#findComment-545846
okay i will remove the H80I but i never have a heat problem it runs at 30 degrees Celsius under full load.
Computer Eqiupment:
https://linustechtips.com/topic/41969-start-up-issue-maybe/#findComment-545863
No. It does not run at 30 degrees Celcius even at full load. It's impossible. AMD's sensors are bad in a lot of their CPUs.
https://linustechtips.com/topic/41969-start-up-issue-maybe/#findComment-546093
