How much harder is it to drive a 2k monitor?
Solved by BrandonTheCat,
Medium to high settings should do fine. I can run 4K at med to high on a 980 so 2560 should be no problem. You might be able to squeeze some settings on ultra You should be fine though
Featured Topics
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2 -
1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
