So I want to replace the corsair 450D stock fans. Give some opinions on what fans i should use. I want two fans on top, one in the back and 2 in the front. I think I'd like the 2 front fans to be 140mm and the rest to be 120mm. So reccomend some fans please. What is the difference between 120mm fans and 140mm.
Heres the build: http://pcpartpicker.com/user/TRambo/saved/#view=99vQzy
https://linustechtips.com/topic/419434-gaming-build-airflow-help/
http://pcpartpicker.com/part/noctua-case-fan-nfp14sredux1200
http://pcpartpicker.com/part/noctua-case-fan-nfs12bredux1200
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
Two Noctua NF series fans on the front for performance airflow.
One Corsair SP120 red fan on the H60 for airflow performance.
Two Corsair AF120 red fans on the top for aesthetics and performance.
what about for the back. And wahts the difference between 120mm and 140mm
