I'm am looking for a cheapish fan controller for a cooler master n200. My power supply will be the antec high current gamer-520w semi modular 80+ bronze.
The case fans I will be using is the 2 fans the case comes with, two cooler master 120mm fans:
http://www.ncix.com/detail/cooler-master-r4-c2r-20ac-gp-120mm-long-58-61078.htm?affiliateid=7474144
And one cooler master 140mm fan:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103078&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8JunctionCA&cm_mmc=AFC-C8JunctionCA-_-na-_-na-_-na&utm_medium=affiliates&utm_source=afc-%zn
I am in Canada so it must be available in Canada. I would like it to work properly and not break. But cheap as possible.
Thanks!
https://linustechtips.com/topic/419180-best-fan-controller/
Is there a cheap 5 bay one. Cause I have five fans. And I don't want a touch screen.
https://linustechtips.com/topic/419180-best-fan-controller/#findComment-5634713
Thanks!
What motherboard are you using? Asus has great onboard fan control and idk, manual fan control seems odd for me. I rather make curves on software and let it bel. If you don't have enough fan headers you can use splitters or a fan hub with sata/molex power that uses the same PWM sign to control all fans.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/419180-best-fan-controller/#findComment-5646744
Motherboard: gigabyte h81-m s2h.
I believe it only has 1 fan header and I thought it would be simpler just to plug my 5 case fans into a controller
I have 2 120mm fans from the n200.
2 cooler master 120mm fans
1 cooler master 140mm
https://linustechtips.com/topic/419180-best-fan-controller/#findComment-5657107
You can use whatever software works to control your CPU fan and get this
http://www.amazon.com/Swiftech-8-Way-Splitter-Power-Connector/dp/B00IF6R4C8/ref=pd_sim_147_3?ie=UTF8&refRID=1CVS125XRM2M8E7TEN4Y
It's a PWM hub, you plug it to your CPU fan header, plug a SATA power cable to it, and every fun will be controlled with the same voltage you are giving your CPU fan
In case your fans are not PWM:
http://www.amazon.com/NZXT-Technologies-AC-GRID-10-M1-Cooling-Black/dp/B00D2ZK2VW
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/419180-best-fan-controller/#findComment-5657852
