Hey guys, I have just build a new A4/A55 build with 2x 3tb Reds. I am  using it as a NAS. When I power on, every turns on, but no display and no beep from speaker. When I take out one or all of the RAM, it beeps once, which is unusual because shouldn't it give an error code for no RAM? I also tried putting in a Dedicated GPU, and same thing happened. Quite frustrating. I also broke the,,, how I explain it.. "attacher" at the end of the pci lane. I am worried if the motherboard is DOA, I may not be able to RMA for that reason.
Specs:
http://pcpartpicker.com/user/amFTW/saved/21Jn
https://linustechtips.com/topic/41796-problem-with-a-new-build/
bad memory or board. try with memory from another system.
Daily Driver:
Case: Red Prodigy CPU: i5 3570K @ 4.3 GHZ GPU: Powercolor PCS+ 290x @1100 mhz MOBO: Asus P8Z77-I CPU Cooler: NZXT x40 RAM: 8GB 2133mhz AMD Gamer series Storage: A 1TB WD Blue, a 500GB WD Blue, a Samsung 840 EVO 250GB
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-542791
That would be on my mind to....
Have you also tested it with just a single stick?
Do you have any other DDR3's around for testing it?
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-542792
Yes, I tried with 2 different sets of RAM, 1 stick then the other, then 2, each time.
That's what I'm guessing, but hoping not.
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-542806
Specs:
http://pcpartpicker....mFTW/saved/21Jn
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-542828
try disconnecting all HDD's except for the one you intend to install the OS on.
try using 1 stick of ram and do so with both sticks of ram.
try removing the APU from the socket,inspecting the pins on the APU to make sure none of them are bent,if any of the pins are bent bend them back into shape carefully and reinstall it.
if possible try with different ram and a different power supply.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-542883
With attacher you mean the clip, that holds PCI-Cards in place on a phsyical side?
If this is the case there should be no reason why you can't RMA a mobo if it's DOA. The "attacher" clearly doesn't affect any electronical components on the MB.
Have you tried posting without any drives attached? You should be able to get into BIOS.
  • Primary PC: i7-3770K@4,6GHz | Thermalright Macho | ASRock Z77 Extreme 4 | 16 GB Corsair Vengeance@1866MHz | 2x Gigabyte 660ti 3GB@1130MHz | 256 GB Samsung 840 | WD Black 1TB | BeQuiet! DarkPower Pro 650W | Zalman Z11
  • Secondary PC: i7-860@3,1GHz | Scythe Katana 3 | ASUS Maximus III Formula P55 | 8GB Corsair Vengeance 1600MHz | 2x Zotac GTX 280@650MHz | WD Velociraptor 500GB | Seagate Barracuda 2TB | BeQuiet! DarkPower Pro 750W | Coolermaster Cosmos S
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-542887
Next time please only make one post, the mods are busy enough as it is :P
http://linustechtips.com/main/topic/41790-new-build-problem/#entry542766
Respect the Code of Conduct!
>> Feel free to join the unofficial LTT teamspeak 3 server TS3.schnitzel.team <<
>>LTT 10TB+ Topic<< | >>FlexRAID Tutorial<<>>LTT Speed wave<< | >>LTT Communies and Servers<<
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-542908
bent pins whoa, you have to be very careful when handling and installing cpu / apu,
are you using a stock cooler?
if so then recommend aftermarket cooler as a stock cooler is only pretty much good enough to get it running, also check and make sure the thermal greese is good quality and properly applied.
got to love Asus components
https://linustechtips.com/topic/41796-problem-with-a-new-build/#findComment-545484
