Enough Power for Build?
Go to solution Solved by MrSuperb,
A System (total) with one GTX600 will draw about 250-300Watt under load from the wall !!!
The 450Watt spec is NOT from the wall, but on the DC side.
250-300Watt from the wall equal 225-270W (PSU @ 90% efficency)
thats about 180-225 Watt excess capacity.
Still a 450-550Watt PSU is a good choice for such a system, as most PSU are most efficent at about 50% load.
CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz
PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount  HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB
You can't spell ignorant without IGN...-TheSLSAMG
https://linustechtips.com/topic/41764-enough-power-for-build/
A 450 watt should be fine:)
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542309
it is just enough, your max power consumption is about 400w
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542312
the max power consumption is not 400w anadtech is using a i7 3960x at 4.3 ghz with card and getting this http://images.anandtech.com/graphs/graph6276/49770.png
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542328
wahaha ... bullshit
A GTX Titan + 3970X oced doesn't only seldom draw 400W from the wall(!)
So I guess that means its enough.
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542338
LOL, 660 draws 195w, and titan only draws 170w, if i remember correctly.
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542342
wahaha ... bullshit
ups, i forgot to quote your post
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542346
http://www.gpureview.com/show_cards.php?card1=680&card2=
again not to be mean or anything but it sounds like your talking out of your ass.
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542356
Yes, enoug power, but the PSU isn't really a high quality one
Which one would you recommend for a build like this?
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542362
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542384
more than enough
PC Specs:  2x GTX 550 ti in SLI - Intel i7 2600k @ 3.4Ghz - Thermaltake Overseer Case - 8 GB Corsair Vengeance Ram - 1TB Harddrive - 500 Watt PSU that came with my old prebuilt pc lawl -  ASUS P8P67 EVO
Peripherals:  Razer Deathadder Black Edition - Razer Arctosa Keyboard - Logitech G53 Headset
Cool song of the day: Chief Keef - Round da Rosey    Changed my profile pic again...                                        Mountain Dew is good. So are video games and music. Oh and unicorns.
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542393
Thanks for everyone's help on deciding this psu is good enough for my friends system. Oh, and good morning I'm going to go make some coffee  :P
https://linustechtips.com/topic/41764-enough-power-for-build/#findComment-542397
