plug them into mobo and see if they spin
My new computer case's fans don't spin. These fans are the default fans for the Phanteks Enthoo Pro Full Tower. All the fans were connected to this circuitry thing in the back and I have no clue what it is.
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/417538-case-fans-not-working/#findComment-5615199
I'm pretty sure you have to connect that circuitry thing(fan hub) into the motherboard
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/417538-case-fans-not-working/#findComment-5615257
I think you need to find a cable that spreads from those circuitry and connect it to the motherboard if not another thing you can do is to connect those cables from the fans that go directly to te cricuitry connect them directly to the motherboard instead, that should do it.If I wrote something wrong or you didn`t understand me its cause I don`t frecuently use english, dont mind to ask anything!
https://linustechtips.com/topic/417538-case-fans-not-working/#findComment-5616063
