So I just ordered an fx 6300 and I do plan on getting a hyper 212 cooler very soon, But my question is, in the mean time can I bump the baseclock and turbo to be the same as a 6350 on the stock cooler? Does the 6350 come with the same cooler as a 6300 or does it get a better stock cooler?
https://linustechtips.com/topic/417011-fx-6300-oc-help/
Erg What are you doing on this PC? I'd get a BeQuiet! Pure Rock but I kinda feel bad that you got a fx 6300 if you are doing it for a gsming build.
A lot of AMD CPUs are just overclocked versions of previous ones Kindda like the fx9590 is basically an overclocked fx8320
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/417011-fx-6300-oc-help/#findComment-5608180
It all depends on the specific board you get, as well as the chip, power supply, and cooler. On my old FX 6300 rig I was able to easily OC to 4.2GHz using a Seidon 120V, however I couldn't go further because the 4+1 VRM on my board wasn't very happy. I would shoot for 4.0GHz, just so you're in the 4GHz klub.
https://linustechtips.com/topic/417011-fx-6300-oc-help/#findComment-5608198
It is for a budget gaming rig, I got the 6300 as an upgrade from my 4300 so I could play Fallout 4 when It releases. I have it paired with a g1 gaming gtx 960. I know the 6350 is just a 6300 with a higher clock speed, I was just wondering if anyone knew if they use the same stock cooler
https://linustechtips.com/topic/417011-fx-6300-oc-help/#findComment-5608205
I have an asus m5a97 r2.0 and a cheap thermaltake 600w psu
https://linustechtips.com/topic/417011-fx-6300-oc-help/#findComment-5608215
