No output on power on - PC starts only if turn off than on quickly PSU. Help!
It is your PSU.
I had the EXACT same issue 2 months ago, but back then I thought it was my motherboard. So I replaced it, and I still have the same issue if I allow my PC to go into hibernate.
I RMA'd my first CX600 2 months after I bought it. I am now on my second CX600 and I am going to replace it with an Xfx PRO650. I suggest you do the same before it potentially damages your motherboard as well. I found out the hard way that a CX series PSU should not be in a gaming system.
Luckily a PSU isn't hugely expensive, a new Gene motherboard is a whole other story. I had the Gene VI, now I am rocking a Gene VII. And I have no plans to let my cheap PSU kill that nice motherboard...
If you replace your PSU and you still have an issue, then it damaged your motherboard. I hope you still can RMA your mobo in this case.
