So I found a slightly used antec h2o 650 water cooler but it doesn't come with any of the backplates. I got my motherboard used, and it already has a backplate on it, so I was wondering if I could use the backplates that is already on the mobo, or if I need to get another socket 2011 backplate?
https://linustechtips.com/topic/416662-motherboard-bracket-question/
Which motherboard do you use?
I think you'll most likey need a new backplate anyways. The backplate that goes behind the motherboard for any AIO cooler has to fit directly into the 4 holes around your CPU.
I cannot imagine that you motherboard came with such a backplate.
I cannot imagine that you motherboard came with such a backplate.[/quote\]
I have a Rampage IV Extreme, and the guy who had it before me had one of the noctua coolers on it. Do you think it would work?
I don't know. I mean it looks like it could work, but the threads for the cooler could be different.
I think you'll need most likely a new backplate.
