Bluetooth interference with wifi?
Solved by Guest,
considering that both wifi and bluetooth use 2.4ghz, then yeah, that can be a problem.
try changing the channels of your hearphones and wifi until they are on different channels, then the problem should be solved.
Featured Topics
halfbood_drag0n ·
2
10
1
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling3
