Yes. That's not the best of SSD choices eather.
( PCPartPicker tells you if it won't fit )
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/416030-will-it-fit/#findComment-5595639
I feel like there's slight corsair fanboyism in this build... Only because you put up the whole build, do you really need vengeance pro ram? All ram is the same... Secondly, have you thought about using a different psu? EVGAs are highly regarded as one of the best and in general corsairs psus are not. Lastly do you really need corsair af fans? There are better options out there for the purpose you are trying to fill. Just wanted to say.
I'm a student currently attending the University of Michigan-Ann Arbor, if you attend or around there please don't hesitate to contact me!
Mudkip: CPU: i5-4670k; Cooler: CM Hyper 212 Evo; Memory: 16GBs Corsair Vengeance DDR3 1600MHz; Motherboard: Gigabyte Z97X UD5H; GPU: ASUS DCUII 770 2GB @ 1254MHz; HDD: Seagate Barracude 1TB; PSU: CX750M; Case: ThermalTake A31 Chaser Thunder
https://linustechtips.com/topic/416030-will-it-fit/#findComment-5595773
