give me the best solution ...
Go to solution Solved by Captain_WD,
~snip~
Hey VideoRusher,
A single SSD should still be faster than a couple of WD Red drives in RAID0. I wouldn't use WD Black drives in a RAID array since they don't have the necessary features to make them safe and stable in a RAID environments.
As the guys suggested, you can use the WD Red drives for rendering since SSD have limited amount of write cycles.
My suggestion would be to keep your programs on a SSD and use the HDDs for the rendering process. :)
Captain_WD.
Never raid hard drives in raid 0 unless you want to lose data.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Use HDDs for rendering. ;) SSD don't like to be writteng often.
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
is there any danger using ssd for rendering??
They will fail earlier.
Tablet: iPad Mini 2
im asking this that most of the websites says use ssd for rendering
some of them are saying use 2 drives in raid 0
which one should i get??
Get something consistent and reliable for raid, intel 730's are a common recommendation.
most sites WD reds are mostly recommended for raid arrays and NaS ...
is 730 is more reliable than wd red in raid 0 array??
WD doesn't make SSDs. I thought that you wanted a SSD, if not get two red drives but they won't be as fast.
oh no no i know that they doesn't have ssds ....
im asking that should i go for a 850 evo or wd red in raid 0 ?? which cost me same.... not about the capasity but the speed...
~snip~
Hey VideoRusher,
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
