Hi, so I was having some troubles with my system the other that I can't install any drivers on my computer, so at the beginingi tried to update my amd apu drivers but it uninstalled them and since that day i couldn't install that amd drivers again. I thought that was some issue with the apu or something with AMD, but no i tried to update my sound drivers and it uninstalled them too, Anyway i need help fiding a solution for this problem.
I can't install any driver.
My system specs are these:
amd a8 7600 with r7 graphics
8gb ram 1866mhz
500 gb storage
500w PSU
Windows 8.1 (Build 9600)
Thank you!
https://linustechtips.com/topic/413899-drivers-help-pls/
Ok, to start with you need to know which drivers are not installed. On win8.1 press 'WindowsKey + X" to open the advanced context menu. Click "Device Manager" and then post a screenshot of what you see there. Specifically, you're looking for items with yellow exclamation marks next to them.
Nine times out of ten, you're going to find all the drivers you need from the mobo manufacturer website. A quick google search should take you straight to the download page.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/413899-drivers-help-pls/#findComment-5568775
ok it's here the screenshot
https://linustechtips.com/topic/413899-drivers-help-pls/#findComment-5568910
Sorry, I had a job to go out and do. What is the model of you motherboard? You should be able to google " --YourMotherboardModel-- driver" and find a download page.
https://linustechtips.com/topic/413899-drivers-help-pls/#findComment-5569240
Here's a download link. Just download all of those, install them, reboot, and make sure everything is working properly.
https://linustechtips.com/topic/413899-drivers-help-pls/#findComment-5569645
Thats the point i can't install it says that the installer stopped working HELP PLS
I did everything and it still
That's very strange behavior during an install. Have you tried doing a system restore or booting into safe mode?
https://linustechtips.com/topic/413899-drivers-help-pls/#findComment-5570043
