I unlocked 4th core on my Phenom II X4 B50 in BIOS. But when I open task manager it only shows 3 cores. Do I have to do something else or?
CPU: AMD Phenom II X4 B50 3.2 GHz // GPU: VTX Radeon HD 6670 1GB DDR3 // MB: Asus M4A88T-M // RAM: 2×2GB DDR3 // PSU: MS PRO 550W ATX P4 // Monitor: Samsung 1280×1024 resolution // Windows 10 64 bit // Mobile: LG G3 32 GB
https://linustechtips.com/topic/413891-unlocking-cores-problem/
You're trying to unlock an Athlon x3, right? Explain what did you change in BIOS (put MB model too)
This is a signature.
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5568672
Was it a X2 550? Maybe one of the cores doesnt work.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5568674
No man I have Phenom x4 but my 4th core wasn't working because I didn't need it. I have Asus M4A88T-M MB. I just set core 4 from off to on and saved. But it still doesn't show 4th on task manager so obviously it's not working.
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5569672
First try clearing CMOS to dump other issues instantly
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5569680
Why is that important?
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5569752
It reset to BIOS default values, that way you can reset issues like incorrect settings
OK thanks I'll see.
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5570077
If the core unlocker cannot enable the core it won't work. You can verify with CPU-Z.
Often the board will say how many cores are active in POST if the core unlock function is active.
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5570402
You just have to like potatoes.
CPU: Intel Core i5 4460 3.2 Ghz \\ Motherboard: MSI H97 PC MATE ATX \\ RAM: Corsair 2x4 GB 1600 Mhz \\ GPU: Asus Strix GTX 970 4 GB DDR5 \\ Storage: WD Caviar Blue 1 TB, 7200 RPM and an external WD Elements 1 TB HDD \\ PSU: Corsair VS650W \\ Case: Cooler Master K350 \\ Optical drive: Samsung R/W 24x \\ OS: Windows 10 64-bit \\ Keyboard/Mouse: Both DELL \\ Display: Samsung 28-inch TV 1080p 60 Hz \\ Phone: Samsung Galaxy S5 Electric Blue 16 GB
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5570485
It says 3 cores activated when I turn it on but in BIOS all four are...
https://linustechtips.com/topic/413891-unlocking-cores-problem/#findComment-5570622
