Hello everyone,
I have a question regarding the placement of my sound card (sound blaster z). I currently have two MSI 980ti gaming 6g video cards and I am not sure whether I should have my sound card above my top video card (potentially blocking the hot air from exiting through an exhaust fan) or if I should put the card in the bottom PCI slot which might hinder the airflow going into the bottom card. Below are two diagrams showing the possible placements.
I am leaning towards having the sound card in the bottom slot since the top card needs as much can help cooling as possible.
https://linustechtips.com/topic/413775-sound-card-airflow-question/
Put it in the bottom slot. Either way, it won't make much difference to cooling for the cards.
This and plus it looks better :D
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
