Hi guys.
I ordered an R9 390 which arrived yesterday, and promptly installed the drivers from the disc before plugging in my graphics card. I was greeted with a black screen from the moment I turned on my computer and the LED for my PCI Express slot the card was plugged into turned red.
I tried uninstalling these drivers with my old graphics card connected so I could get a display on my monitor and then I installed a different set of drivers recommended online but had the same issue.
I even tried a complete wipe and rebuild of my PC but I still can't get the new card to work.
Has anybody else experienced any similar problems and if so, how did you manage to sort them out?
I was looking forward to the 390 but I'm starting to think I should've gone with a GTX 970 instead!
Specs:
Intel i7 2600k
Asus P8Z67-V PRO
Corsair GS800 800W PSU
Corsair Vengeance 2 x 4gb
Corsair Force Series 3 120GB SSD
https://linustechtips.com/topic/413283-msi-r9-390-problems/
Hi guys.
what PSU are u using?
CPU: FX8320 @ 4.2GHZ, GPU: R9 390 PCS+Cooler: Hyper 212 Evo, MotherBoard: ASRock 970 Extreme 3 r2.0, PowerSupply: EVGA 600b 80+Bronze, Storage: seagate Barracuda 1TB SSHD & Case: Corsair Carbide 200r
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561130
have you used iGPU? and is ur GPU at the top slot?
I started off with the GPU in the top slot, yes. I did try changing it to the second slot but it still didn't work. And no, I haven't heard of iGPU, not sure what that is!
Sorry, edited my specs into my first post. I'm using a Corsair GS800 800W so it shouldn't be a problem with the PSU.
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561150
Hi guys.
Specs:
Intel i7 2600k
Asus P8Z67-V PRO
Did you go to your bios, and make sure the PCIE is the primary? By default it will be the onboard igpu. (igpu is the GFX chip on the CPU)
igpu - internalGPU
Using the PCIE card DVI/HDMI/VGA/DP outputs for your monitor?
Once the bios is set to PCIE, the monitor cables should be in the new GPU, and it should be fine.
The setting is usually in an advanced menu, or a sub-menu in that section somewhere.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561155
igpu - internalGPU
It was set to primary with my old card. The problem is the second I plug in the new card it black screens from the moment I turn on my PC so I can't get to the BIOS to check settings.
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561168
After that,....Then I'd RMA it.
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561174
i know this kind of sounds like common sense but did u try installing the latest catalyst driver( i.e catalyst 15.7)
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561181
His first post states he did try changing drivers, same thing happens.
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561190
Hi guys.
Specs:
Intel i7 2600k
Asus P8Z67-V PRO
so what i suggest u do is get this software DDU  which should completly uninstall everything realted to GPU and then download latest 15.7 drivers from amd and try it. if it doesnt work RMA it
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561215
yea because LTT had artifacts with theirs. I guess there made in a potato factory.
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561492
i dont understand what do u mean? and there seems to be a lot of problems with msi related 3XX cards, but the cooler is exceptional! one of the best in the market!
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5561706
When Linus got the R9 390 their GPU was showing artifacts. That's why the video for the 390 was delayed
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5562456
Wasn't it the Fury X? And it was artifacting when they started to overclock.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5562764
I have MSI R9  290x, had the problem where nothing is displayed although signals are given to monitor. Card had a bios switch (legacy and UEFI, located in the place of uber and quiet switch of reference 290x). Changed the switch to one of them and changed the primary display to PCI express in BIOS (motherboard) and it started working.
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5563519
woops my bad, AMD product naming is confusing me again
Not up to date aren't ya?  ;)
r9 Fury X
r9 Fury
r9 390x
r9 390
r9 380
r7 370
r7 360
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5565362
r9 Fury X
r9 Fury
r9 390x
r9 390
r9 380
r7 370
r7 360
and a nano somewhere in there :P
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-5588435
  • 2 months later...
Drivers from the disk.................................
https://linustechtips.com/topic/413283-msi-r9-390-problems/#findComment-6329644
