Case and cooler compatiblity
Solved by SeanAngelo,
On pcparticker I saw this note at the bottom:
Unable to verify the Rosewill Galaxy-01 ATX Mid Tower Case and the Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler are compatible.
Can anyone verify if they are compatible?
Thanks
considering the 212 evo is 6.3 inches tall and the case is 8.2 inches wide + add the cpu socket height and motherboard, it probably wont fit...
http://www.rosewill.com/products/2478/ProductDetail_Specifications.htm
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
http://www.coolermaster.com/upload/product_feature/Hyper212_Plus_2D_drawing.jpg
