do you use chrome?
disable hardware acceleration.
this isn't that big of a deal in my opinion.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
Didn't work :/
I want to fix this because it is also drawing more power, in addition to the temps.
it's sipping power. don't worry about power.
60C isn't that hot either. it's warm certainly, but that seems like an air flow issue to me.
if you're super duper really stressing you can always manually downclock it with MSI afterburner or EVGA precisionX
