Uhmm hey guys i know this question has been asked many times and I know that these might sound a bit stupid but I just want to confirm it, is it ok to clean my computer chassis and fans with a vacuum cleaner? I mean with all the electronics stripped out just the pc chassis and fan.....thanks in advance  :D  :D  :D
https://linustechtips.com/topic/411572-pc-cleaning-question/
Why? if you want to remove then anyway from the PC, why not clean then with a better method?
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539847
A normal vacuum cleaner is only going to get so much - about as much as you'd clean while just blowing air into the case from your mouth.
If you want to clean it (if it is just the case and fan) then get a can of compressed air and a rag, wipe out the surface dust and spray out the buildup.
So yes, it's technically okay to do so, but it won't be very effective.
"Epic Voice, Quality Content"
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539878
Sure, but at that point, it's just better to use a rag and/or a brush.
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539894
wow that was fast thanks for the reply man you're awesome, BTW I usually clean my board,cards and all electronics with compressed air so i have to remove them so that i could clean the chassis, so i was thinking if it was possible to do so since the fans and the chassis sometimes are really a pain in the a** to clean LOL, but if you have better alternatives can you give some tips? thanks man
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539906
just get a air compressor and you will be fine! blow the dust out of the components. be sure it is a dry air compressor. no need to take everything out just grab you're tower and clean blow it out.
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539915
A brush is normally the best option ;)
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539917
thanks dude, and yeah i have tried that but both my nose and skin are quite allergic to dust they both itch like hell upon contact LOL
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539925
a brush is like hair it makes static electricity! you need a ESD (Electro Static Discharge) Brush to do it. Never use a regular brush.
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539926
a brush is like hair it makes static electricity! you need a ESD Brush to do it. Never use a regular brush.
You are right.
Something like this: http://www.amazon.de/Handgriff-Statik-B%C3%BCrste-Reinigungsb%C3%BCrste-schawrz/dp/B00KHV267M/ref=sr_1_sc_3?ie=UTF8&qid=1437415961&sr=8-3-spell&keywords=ESB+pinsel
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539937
thanks man I have tried that, but its just that my nose and skin aren't so happy with the dust all over the place LOL
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539957
do it in open air place like you're garage or just outside in a dry day. you wont get dust :)
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5539973
Well the thing is here in my area when i do it outside one small gust from the wind and pretty much all the dust i have cleaned will probably return with sand included LOL, well i guess I have to tackle that dust mano-a-mano again LOL it seems like my only choice is to buy some facemask and wear a jacket LOL, but anyways thanks for the replies I really appreciate it
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5540025
For me easiest way is a Air compressor.
Have you none and dont want to spent the money? Take a normal stand bicycle pump with a needle for balls (Football, Basketball,...)(needed for high enough pressure)
When you have that you only need a second person because it is nearly impossible to pump and hold the needle near the dusty compnents at the same time.
https://linustechtips.com/topic/411572-pc-cleaning-question/#findComment-5540093
