Need some advice .
Go to solution Solved by Guest,
You Cant, the GPU is too good.
But adding a 270x would increase performance massively.
@dannolt
The performance would just end up being the two 270x cards instead of the two and the APU.
You would, however, get a respectably good performance from the 270x with an APU, so I would recommend it if it's for gaming.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/411132-need-some-advice/#findComment-5534422
He means crossfire between the APU and 270x which is not possible.
AMD made it so that GPUs upto the R7 250 could run in crossfire with the APU for mild improvements in performance.
https://linustechtips.com/topic/411132-need-some-advice/#findComment-5534434
Oh......my bad.
DAYTONA
https://linustechtips.com/topic/411132-need-some-advice/#findComment-5534444
