YouTube link don't work. One thing though why such a high end system but cheap out on the air cooler? If you want sir I'd get a BeQuiet! Dark rock pro 3 or non pro version. If you want water cooler a corsair h100i or NZXT x61 kraken, plus what are you using this for. The more logical one seems the one in PCPartPicker.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/410957-i-need-some-help/#findComment-5532665
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£267.38 @ Amazon UK)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler (£104.80 @ CCL Computers)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard (£99.98 @ Amazon UK)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory (£71.03 @ More Computers)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive (£265.00 @ Aria PC)
Storage: Western Digital Red Pro 3TB 3.5" 7200RPM Internal Hard Drive (£124.98 @ Ebuyer)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card (£579.59 @ Overclockers.co.uk)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case (£89.99 @ Aria PC)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Operating System: Microsoft Windows 8.1 OEM (64-bit) (£75.09 @ Amazon UK)
Total: £1677.84
Generated by PCPartPicker 2015-07-19 21:27 BST+0100
Better, what would you be doing on this? Editing? Rendering? 1440p gaming? This build will work for all three of those. I'd just get the 4790k also because games are gonna start using those extra threads soon haut like some are using more then 4 cores.
https://linustechtips.com/topic/410957-i-need-some-help/#findComment-5532763
That seems like a solid choice for what you are trying to accomplish albeit you could probably find a little cheaper Z97 motherboard, unless you have ot use that one.
For storage go with the 500GB Samsung SSD. It is more value for money, as it has been dropping in price lately, so it is now cheaper to buy 2x 500GB SSD then 1TB one.... It is also slightly cheaper to buy one 500GB one then 2x 250GB ones.
So 500GB 850Evo SSD, most bang for your buck atm....
https://linustechtips.com/topic/410957-i-need-some-help/#findComment-5533077
