Hi,
I recently sold the Andriod phone that I got with my pay monthly plan from Orange and bought an iPhone.
When looking on the internet, people are saying I need to update the carrier settings or something like that so that Orange know that I now have an iPhone and so that I can get all the features of it.
Does anyone know how I can do this?
Thanks in advance,
- Harry
https://linustechtips.com/topic/410689-orange-ee-mobile-help/
Hi,
Thanks in advance,
- Harry
Networks like Vodafone auto-detect when you change your phone and tell you that they're going to send a text message with the new internet data. That message comes through(With some fancy MMS attachment) and tapping the Install button simply updates the internet connection data.
I don't know whether the process is the same on iPhones or not. The best you can do is to either call your network and ask them to send the internet connection information, or just google 'EE mobile internet settings' (lmgtfy link) and click one of the links.
Then, in a new tab, find out how to change the internet APN on your phone to the details you just found.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/410689-orange-ee-mobile-help/#findComment-5529413
Thanks ;D
https://linustechtips.com/topic/410689-orange-ee-mobile-help/#findComment-5529660
