Long loading and sleep problems
Go to solution Solved by burnttoastnice,
Have you installed all the chipset drivers for the new mobo?
Edit: I'm pretty confident that the desktop taking a long while to load would be because Windows is trying to validate the license, since you've changed 'your computer' according to Microsoft's EULA. (Microsoft considers a motherboard change a system change)
While the desktop is loading, is your screen black?
OK, so I recently upgraded my gaming system from an A8-7600 and an A88X-Pro from Asus to a FX-8350 and a 970 Extreme 4 from AsRock (I installed all new drivers and such). What i have been noticing and annoyeds by is whenever i start my system and put in my windows 8.1 PIN, I then have to wait a minute or more for it to actually log me in, and then 2-3 minutes more for my desktop to load. Also, if I try to sleep my computer, the system instead shuts down, I also had noticed these problems for 1-2 times when I first built this system, but after 2 times it NEVER happened again. Please help.
Specs:
Fx-8350 @ 4.00Ghz (no OC)
AsRock 970 Extreme 4
8 GB DDR3 @ 1800Mhz
1Tb WD Blue (basic storage)
256GB Kingstion SSD (boot and games)
Radeon HD 6970 @ 905Mhz (OC)
[insert stuffs here]
https://linustechtips.com/topic/410377-long-loading-and-sleep-problems/
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
I just went back, and realized i haden't, but I went to ASRock's website, and they don't include chipset drivers... I have no idea why
Where could i get them?
I'm not too sure, if they're not on the manufacturer site then Windows should install them automatically. I swapped hard drives out of two laptops today because one stopped working - when I put it into the new laptop and popped open Device Manager it was pretty much installing everything.
Open device manager and see if there's any 'unknown device' listed
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
