Hi there. I recently completed my project utilizing the main hardware components from my Antec 902 and refreshing the Mobo, ram, GPU and CPU. Recently ive had problems switching the PC on for the first time every day. When I press the power button everything lights up for a split second and it immediately powers down, no bios codes or beeps or anything. I try 3 or 4 times and it repeats this until it boots fine, with no further issues. If I shut down and hit the power button it works perfect.
Im suspecting my Corsair HX620 is the culprit but can't be sure, anyone had any experience with this issue?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/410191-pc-power-up-issue/
probably the psu if its coming on after a few tries.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/410191-pc-power-up-issue/#findComment-5523804
ah ok, well I guess the next question is, what PSU should I replace it with ?
Ryzen Ram Guide
https://linustechtips.com/topic/410191-pc-power-up-issue/#findComment-5523884
Decided to grab a Fractral Design R3 Newton 1000w in white
THanks
Ryzen Ram Guide
https://linustechtips.com/topic/410191-pc-power-up-issue/#findComment-5524407
