I was wondering if a particular windows 8.1 key is tied to one and only ISO. So for instance, would it be possible to use a whole bunch of keys to activate windows 8.1 with one iso, or is there only one key that will activate that iso. TIA
https://linustechtips.com/topic/409826-81-iso-and-keys/
no, you can use a lot of keys with 1 iso. unlimited amount of keys will work with 1 iso
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/409826-81-iso-and-keys/#findComment-5519441
No not really. you can use any key with any ISO as long as the key is valid
That being said, you can use the Microsoft ISO downloading tool and you input your key there, then that key is embedded somewhere in the ISO files so that you can use that same key to activate Windows when you install it. I'm pretty sure it's an easy manual change though, you can just skip inputting a product key during installation altogether
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/409826-81-iso-and-keys/#findComment-5519442
https://linustechtips.com/topic/409826-81-iso-and-keys/#findComment-5519448
