I being planning this build for 3-4 months now and it is now that I bother seeking help.
I will use this computer for everyday use but mostly gaming, I hope to run most games on 60fps 1080p and maybe 1440p if I bother getting a new monitor.
this is the build I'm most sure of in pcpartpicker http://pcpartpicker.com/p/rRgvt6
I am mostly clueless about the motherboard and PSU. budget is $2000 but I want to keep it as low as possible.
I plan on buying the cpu i7 4790k in micro center when I go to Houston Texas next month. I'm currently in south Florida so if I can get parts cheap here let me know. Also will the gigabyte geforce gtx 980 ti fit in a corsair 450D mid tower case?
I'm thinking of overclocking but I'm not really sure
EDIT:
Here's an idea of what I'm trying to build, I want a pc that will be able to run on  60fps 1440p MGS5: the phantom pain
Will a gtx 980 be enough to handle it? or I should go for a gtx 980 ti.
I want a pc that will last me for years and that will be able to have plenty of upgrades if needed.
I'm set on getting a new monitor so what is a good 1440p monitor to get for gaming. The build can go over the budget if needed for the monitor.
http://pcpartpicker.com/p/LfZ4Vn < I made some changes to video card, cpu cooler, and ssd.
https://linustechtips.com/topic/409731-first-time-building-a-computer-i-need-help/
go for this instead
http://pcpartpicker.com/p/tfvwvK
it has the better version of the cpu cooler
a faster and more trustworthy ssd
a cpu that is more budget friendly but the best in the buisness for gaming
and the rest looks good
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
http://pcpartpicker.com/p/FMVqMp
I would say that 1440p is a minimum with that GPU. If you are going to play at 1080p go for a 980.
What I changed:
Cooler: Just a different one, little bit quieter and better temps :)
Case: Nicer case too.
SSD: The V300 is pretty bad, so the MX100 will be a fine replacement :)
Peripherals: You don't have to spend that much on peripherals but it'll be badass if you did.
Definitely go for 3440X1440 or 2560X1440 is you are going to get that 980TI.
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
PCPartPicker part list: http://pcpartpicker.com/p/4rcZ7P
Price breakdown by merchant: http://pcpartpicker.com/p/4rcZ7P/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard  ($79.99 @ Micro Center)
Memory: Apotop 8GB (2 x 4GB) DDR3-1600 Memory  ($42.99 @ Newegg)
Storage: Crucial BX100 120GB 2.5" Solid State Drive  ($63.96 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ Best Buy)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($429.98 @ SuperBiiz)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($93.99 @ SuperBiiz)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($89.99 @ NCIX US)
Wireless Network Adapter: TRENDnet TEW-804UB 802.11a/b/g/n/ac USB 2.0 Wi-Fi Adapter  ($15.68 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($27.99 @ Amazon)
Total: $1210.52
Generated by PCPartPicker 2015-07-17 19:36 EDT-0400
A very capable build able to handle 1080p,1440p, and even 4k with ease. A intel xeon cpu that performs like an I7 for all your cpu needs. A very reliable BX100 ssd to load your system fast, and the very capable R9 390x to handle your gaming needs. A dvd writer in case you can't make a usb boot drive, a ac capable wireless adapter, and a gold rated psu from seasonic make this a very good gaming build, for $800 under your max budget.
