Hi Guys,
So I am looking for opinions for cases. Please don't recommend NZXT, those are pretty expensive. My budget is about RM150. I need a full ATX Case, with a strong body and good airflow, if there are extra features, then its a bonus to me :)
Here is what I found
DeepCool Tesseract Window
Xigmatek ShockWave
CM K280/K350/K380
AeroCool Predator X1
AeroCool Templarius Ferrum
ThermalTake H21-H25 Versa
Enermax Thorex
AEROCOOL Casing ATX STRIKE-X COUPE BLACK
AEROCOOL Casing ATX CYCLOPS ADVANCE RED (CYCLOPS-ARD)
Sorry for the long list
THANKS to anyone who contributes here
https://linustechtips.com/topic/409469-best-full-atx-case/
When you say Full ATX, do you mean "full tower" or just any case that fits a full size ATX motheboard?
Are there specific features you need, like a lot of drive bays or room for custom water cooling etc?
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/409469-best-full-atx-case/#findComment-5515337
