I recently got a new build and my motherboard is a ASrock H97 Pro4 LGA 1150. after completing the build i set everything up which seems to be working fine except for the fact that i am receiving no connection to the internet. Am i supposed to update the drives or what? How can i even do that if i have no connection to the net except by using a usb. Am i messing something up? The lights on the Ethernet are both working fine saying it has activity but i cant connect to the net...
Plz help thanks in advance!
https://linustechtips.com/topic/409202-not-sure-what-the-problem-is/
You have to get the ethernet driver from the website in order to do that. I have had to do it for all 3 motherboards I've worked with ranging from lga 775 to lga 1150.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
@AoGeko
Download the nic driver on another computer for your motherboard.
Put it on a USB then install.
Download all other drivers from the site when you can connect to the internet.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
@AoGeko
Alright thank you guys i was literally just now trying to delete this topic because i figured that would be my solution lol thanks for the quick response!
