Hello People,
I want to tidy up my command center and need some help, I am after two 27 inch monitors and a dual screen mount (table clamp).
Would prefer the monitors visually look the same or at least look close to the same, monitor one will be used for PC and monitor two for Xbox one.
I don't do much pc gaming but was originally thinking of getting a higher res 1440p IPS screen for the pc and a normal 1080p with low input lag for the Xbox as I play a lot of COD.
What I was looking at:
PC monitor - Benq xl2730z (not isp, but looks like the second screen) or Benq GW2765HT but it looks like it has a gloss finish which is a bummer.
Xbox monitor - Benq rl2755hm (known to be good for console gaming with low input lag)
Dual mount - I have made my mind up to go with the Atdec Visidec dual display stand. Unless you guys think otherwise
Let me know your thoughts and what you recommend can be other brands also.
Thanks
https://linustechtips.com/topic/409159-dual-monitors-plus-stand/
