Replacement for r9 290x
Go to solution Solved by Guest,
780 with a good oc is better than a r9 290x but a good oc is not a guarantee but since you tried a ghetto gpu aio that might be something you are interested in (experimenting and voiding warranties).
But i would go for another r9 290x, its just cheaper for great performance.
I just killed my r9 290x (the geto mod for a aio (uneven pressure which cracked the gpu die)) I can get another one for 200$ or I can get a gtx 770 for the same price and for an extra 75 I can get a gtx 780. my plans are to go 4k eventually (sometime soon) and was wondering which of the cards I should get because everything else is basically out of my price range
https://linustechtips.com/topic/408767-replacement-for-r9-290x/
R9 290X no doubt
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/408767-replacement-for-r9-290x/#findComment-5506331
290x blows the 770 out of the water same with 780 tbh
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
https://linustechtips.com/topic/408767-replacement-for-r9-290x/#findComment-5506339
https://linustechtips.com/topic/408767-replacement-for-r9-290x/#findComment-5506404
You can also oc the 290x so it still wins.
https://linustechtips.com/topic/408767-replacement-for-r9-290x/#findComment-5506416
that's what I was thinking
https://linustechtips.com/topic/408767-replacement-for-r9-290x/#findComment-5506436
oh forgot to say that it is the tri-x version :)
A Tri X 290x? Nice... That card can OC no doubt. A good OC on the 290x trumps even the 780 with a high OC.
        Core                   Mem                    Score                 Graphic score
Not too far from a 780 SLI too.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/408767-replacement-for-r9-290x/#findComment-5507002
