ATX Case
Go to solution Solved by colinreay,
I might go for something like this on a budget... Fractal makes really good cases, and the core looks great. It has nice features like multiple dust filters, and includes 2 great 120mm fans. It is 7.6 x 17 x 17.7 inches. It isn't tiny, but it is pretty small for an atx! You can get it for $46.99 here!
hy,
i am looking around for a new pc case.
i want to decrease the size of my rig.
i have a atx system at the moment and i want to know what the cheapest way is to get a smaller rig.
Is there a smal atx case or is the only way to get a new motherboard and case?
Thanks
https://linustechtips.com/topic/408741-atx-case/
I like this case: http://www.amazon.com/Corsair-CC-9011048-WW-Windowed-Performance-Computer/dp/B00H8JLM94/ref=sr_1_2?s=electronics&ie=UTF8&qid=1437062198&sr=1-2&keywords=corsair+carbide+air
Here are the dimensions: 16.3 x 13.1 x 18 inches ; 16.3 pounds
I like the case with the white and black but there are also other colors.
https://linustechtips.com/topic/408741-atx-case/#findComment-5506017
He's asking to make it smaller, not make it wider.
OP what's your current case, we can offer suggestions if we know what we need to beat size wise
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/408741-atx-case/#findComment-5506038
I like good humans and good food
https://linustechtips.com/topic/408741-atx-case/#findComment-5506157
