I like to play games, stream and record videos for YouTube. I am building a newer, better PC from scratch and would like some help, I wouldn't like you to redo my whole build.
HERE IS MY LIST OF THINGS THAT I WOULD LIKE CHECKED BEFORE I PURCHASE THEM:
I have already bought a SanDisk 240Gb SSD and am not sure that I need a hard drive as well.
Is this case compatible (CiT Invader 12 cm Gaming Case - Red: Amazon.co.uk: Computers & Accessories).
I also here are 2 PSU's and I would like to know if they are good and compatible:
CiT 750W 12cm Silent Fan Power Supply - Gold Edition: Amazon.co.uk: Amazon Warehouse Deals
CiT 600W Power Supply Unit with PSU and Dual 12V Rails - Black Edition: Amazon.co.uk: Amazon Warehouse Deals
I also found a cheap motherboard that I am not so sure about.
This is my current build status, excluding the case and psu as they may have compatibility issues:
Type|Item|Price
**CPU** | [intel Core i5-4460 3.2GHz Quad-Core Processor](http://uk.pcpartpick...u-bx80646i54460) | £141.20 @ More Computers
**Memory** | [Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1600 Memory](http://uk.pcpartpick...y-hx316c10fwk28) | £38.39 @ Amazon UK
**Storage** | [sandisk Ultra II 240GB 2.5" Solid State Drive](http://uk.pcpartpick...sdssdhii240gg25) | Purchased For £54.99
**Storage** | [Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive](http://uk.pcpartpick...rive-wd3200aajs) | £18.99 @ Amazon UK
**Video Card** | [MSI Radeon R9 380 4GB Video Card](http://uk.pcpartpick...d-r9380gaming4g) | £177.07 @ Ebuyer
**Operating System** | [Microsoft Windows 8.1 OEM (64-bit)](http://uk.pcpartpick...oft-os-wn700615) | £75.09 @ Amazon UK
**Wireless Network Adapter** | [TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter](http://uk.pcpartpick...-card-tlwn881nd) | £12.95 @ CCL Computers
**Other**| AvP Case| £26.49
**Other**| PSU - Aerocool Intergator 600w| £37.49
**Other**| MSI B85-G41 PC MATE| £46.95
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **£629.61**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2015-07-15 18:21 BST+0100 |
https://linustechtips.com/topic/408682-build-help-compatibility-and-cost-help/
Do not buy anything from CIT and those PSUs are very bad
Like the guy above said look a cheap Fractal Design case like the Core 2300/2500/3300/3500 or the NZXT S210/S340(if you can afford) or a Corsair SPEC 01
Those PSUs are of poor quality and it's never good to go with a low name brand or no name as it could fry your system and that case is old designed and bad. I would only get PSUs from
Corsair
Coolermaster
Antec
EVGA
Thermaltake
Fractal Design
Seasonic
Silverstone
Be Quiet
Enermax
XFX
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
@OAcesync @Mug
Do either of you 2 have any suggestions for cheap windowed PC Cases?
And any idea for a cheap PSU 600w+?
Cheap windowed case would be the Corsair Spec 01 it's an good case for budget build
Best cheap PSU I can think of is the Antec Current High Gamer which is great quality PSU or literally anything from Seasonic they make the best PSUs
If you're unsure about your PSU then go here: http://linustechtips.com/main/topic/404921-strmfrmxmns-psu-whitelist/
        Setup
The motherboard may need a BIOS update before the i5-4460 can be used. According to the MSI web page for the motherboard BIOS level 2.5 or above is required for Haswell Refresh cpu.
The AvP case is ATX so any ATX, mATX, or mini-ITX motherboard will fit in it.
BitFenix Neos White/Red ATX Mid Tower Case is a decent case with a bottom mount psu. It comes in a couple of different colors.
Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1866 Memory is just a few pennies more and offers slightly better performance.
Don't buy an hdd unless you need one. If you do, try to get a 1TB model.
http://www.kitguru.net/components/power-supplies/zardon/aerocool-integrator-600-watt-psu-review/7/ says some not bad things about the psu in the OP. Like the author I would caution against getting such a low end unit unless absolutely necessary. A bad psu can shorten the lifespan of various electronics. It can lead to instability and random glitches.
